Introduzione
In this guide, we will be showing you how to remove and replace the Display Assembly.
Parti
Nessuna parte richiesta.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer.  After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Turn the computer over and open the display to 180-degree angle.
    • CAUTION: Place the computer on a soft and clean surface to avoid scratching the display.
  2. Place the computer on a flat surface with the display facing down.
    • Place the computer on a flat surface with the display facing down.
  3. Remove the screws that secure the display assembly to the palm rest and keyboard assembly.
    • Remove the screws that secure the display assembly to the palm rest and keyboard assembly.
  4. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  5. Remove the antenna cables from the routing guide on the palm rest and keyboard assembly.
    • Remove the antenna cables from the routing guide on the palm rest and keyboard assembly.
  6. Lift the display assembly off the palm rest and keyboard assembly.
    • Lift the display assembly off the palm rest and keyboard assembly.
  7. CAUTION: Place the computer on a soft and clean surface to avoid scratching the display.
    • With the display facing down, align the screw holes on the display hinges with the screw holes on the palm rest and keyboard assembly.
  8. Replace the screws that secure the display assembly to the palm rest and keyboard assembly.
    • Replace the screws that secure the display assembly to the palm rest and keyboard assembly.
    • Turn the computer over and close the display.
Linea Traguardo
Terrence15
Membro da: 18/12/2017
70.653 Reputazione
442 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 30
Tutti i Tempi: 135
