Salta al contenuto principale
Dell Inspiron 15 5577 Gaming Hard-Drive Replacement
Cosa ti serve
  1. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement, Hard-Drive: passo 1, immagine 1 di 1
    • Turn your Dell Inspiron laptop up side down to locate a screw at the top of the device.
    • Unscrew the back cover with your Phillips Head screwdriver.
  2. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: passo 2, immagine 1 di 1
    • Remove the back cover. If you're having difficulty removing it, use a plastic opening tool, and pry the back cover away from the laptop.
  3. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: passo 3, immagine 1 di 1
    • Unscrew all 4 screws located around the hard drive.
  4. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: passo 4, immagine 1 di 1
    • Remove the cable above the hard drive. This can be done with a gentle tug perpendicular to the surface it is attached to.
  5. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: passo 5, immagine 1 di 1
    • Remove the hard drive. If you're having difficulty removing it, use a plastic opening tool.
  6. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: passo 6, immagine 1 di 1
    • Unscrew the four screws on the hard drive casing.
  7. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: passo 7, immagine 1 di 1
    • Remove the hard drive casing. If you're having difficulty removing it, use a plastic opening tool.
Conclusione
[deleted]
Membro da: 10/31/19
346 Reputazione
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 37
Tutti i Tempi: 818
