Salta al contenuto principale
Dell Inspiron 15 5577 Gaming Fans Replacement
Cosa ti serve
  1. Dell Inspiron 15 5577 Gaming Fans Replacement, Fans: passo 1, immagine 1 di 1
    • Unscrew the base cover plate to locate the gaming fan.
  2. Dell Inspiron 15 5577 Gaming Fans Replacement: passo 2, immagine 1 di 1
    • Remove the base cover.
  3. Dell Inspiron 15 5577 Gaming Fans Replacement: passo 3, immagine 1 di 1
    • Gently tug on the battery cable in order to disconnect it from the motherboard.
  4. Dell Inspiron 15 5577 Gaming Fans Replacement: passo 4, immagine 1 di 1
    • Loosen the screws that secure the battery in place.
  5. Dell Inspiron 15 5577 Gaming Fans Replacement: passo 5, immagine 1 di 1
    • Carefully pull the battery out of the laptop.
  6. Dell Inspiron 15 5577 Gaming Fans Replacement: passo 6, immagine 1 di 1
    • Remove the cable above the hard drive.
  7. Dell Inspiron 15 5577 Gaming Fans Replacement: passo 7, immagine 1 di 1
    • Loosen the screws that secure the hard drive.
  8. Dell Inspiron 15 5577 Gaming Fans Replacement: passo 8, immagine 1 di 1
    • Carefully remove the hard drive.
  9. Dell Inspiron 15 5577 Gaming Fans Replacement: passo 9, immagine 1 di 3 Dell Inspiron 15 5577 Gaming Fans Replacement: passo 9, immagine 2 di 3 Dell Inspiron 15 5577 Gaming Fans Replacement: passo 9, immagine 3 di 3
    • Flip the laptop over and open the lid.
    • Remove the palm rest.
  10. Dell Inspiron 15 5577 Gaming Fans Replacement: passo 10, immagine 1 di 1
    • Carefully unsecure the rest of the shell on the base of the computer.
  11. Dell Inspiron 15 5577 Gaming Fans Replacement: passo 11, immagine 1 di 1
    • Remove the keyboard.
  12. Dell Inspiron 15 5577 Gaming Fans Replacement: passo 12, immagine 1 di 1
    • Loosen the screws securing the metal plate and contents of the base.
  13. Dell Inspiron 15 5577 Gaming Fans Replacement: passo 13, immagine 1 di 1
    • Remove the plate.
  14. Dell Inspiron 15 5577 Gaming Fans Replacement: passo 14, immagine 1 di 1
    • Unscrew and remove the first fan from the base of the laptop.
  15. Dell Inspiron 15 5577 Gaming Fans Replacement: passo 15, immagine 1 di 1
    • Remove the fan's cable from the board.
  16. Dell Inspiron 15 5577 Gaming Fans Replacement: passo 16, immagine 1 di 1
    • Repeat steps 14 and 15 for the remaining fan.
Conclusione
Altre 4 persone hanno completato questa guida.
Julia Cabral
Membro da: 10/31/19
403 Reputazione
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 47
Tutti i Tempi: 2,431
