Salta al contenuto principale
Dell Inspiron 15 5576 Gaming Hard Drive Replacement
Cosa ti serve
  1. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Disconnecting the Hard Drive Cable: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Using the pull-tab, disconnect the hard-drive cable from the system board.
  2. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Remove the Screws: passo 2, immagine 1 di 1
    • Remove the four screws (M2x5) that secure the hard-drive assembly to the computer base.
  3. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Lifting the Hard Drive Assembly: passo 3, immagine 1 di 1
    • Lift the hard-drive assembly, along with its cable, off the computer base.
  4. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Disconnect the Interposer: passo 4, immagine 1 di 1
    • Disconnect the interposer from the hard-drive assembly.
  5. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Remove the Screws: passo 5, immagine 1 di 1
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  6. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Remove the Hard Drive Bracket: passo 6, immagine 1 di 1
    • Remove the hard-drive bracket off the hard drive.
  7. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Align the Screw Holes: passo 7, immagine 1 di 1
    • Align the screw holes on the NEW hard-drive bracket with the screw holes on the hard drive.
  8. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Replace the Screws: passo 8, immagine 1 di 1
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  9. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Connect the Interposer: passo 9, immagine 1 di 1
    • Connect the interposer to the hard-drive assembly.
  10. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Align the Screw Holes: passo 10, immagine 1 di 1
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  11. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Replace the Screws: passo 11, immagine 1 di 1
    • Replace the four screws (M2x5) that secure the hard-drive assembly to the computer base.
  12. Dell Inspiron 15 5576 Gaming Hard Drive Replacement, Connect the Hard Drive Cable: passo 12, immagine 1 di 1
    • Connect the hard-drive cable to the connector on the system board.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.243 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 575
