Salta al contenuto principale
Dell Inspiron 15 5565 Display Assembly Replacement
Cosa ti serve
  1. Dell Inspiron 15 5565 Display Assembly Replacement, Remove the Battery Cable: passo 1, immagine 1 di 1
  2. Dell Inspiron 15 5565 Display Assembly Replacement, Remove the Display Cable: passo 2, immagine 1 di 1
    • Note the display cable routing and remove the cable from its routing guides.
  3. Dell Inspiron 15 5565 Display Assembly Replacement, Disconnect the Display Cable: passo 3, immagine 1 di 2 Dell Inspiron 15 5565 Display Assembly Replacement, Disconnect the Display Cable: passo 3, immagine 2 di 2
    • Lift the latch and disconnect the display cable from the system board.
  4. Dell Inspiron 15 5565 Display Assembly Replacement, Remove the Screws: passo 4, immagine 1 di 1
    • Remove the screws that secure the display hinges to the palm rest and keyboard assembly.
  5. Dell Inspiron 15 5565 Display Assembly Replacement, Open the Display Hinges: passo 5, immagine 1 di 1
    • Open the display hinges.
  6. Dell Inspiron 15 5565 Display Assembly Replacement, Lifting the Assembly: passo 6, immagine 1 di 1
    • Lift the palm rest and keyboard assembly off the display assembly.
  7. Dell Inspiron 15 5565 Display Assembly Replacement, Placing the Palm Rest: passo 7, immagine 1 di 1
    • Place the palm rest and keyboard assembly on the NEW display assembly.
  8. Dell Inspiron 15 5565 Display Assembly Replacement, Press the Hinges Down: passo 8, immagine 1 di 1
    • Using the alignment posts, press the display hinges down on the palm rest and keyboard assembly.
  9. Dell Inspiron 15 5565 Display Assembly Replacement, Replace the Screws: passo 9, immagine 1 di 1
    • Replace the screws that secure the display hinges to the palm rest and keyboard assembly.
  10. Dell Inspiron 15 5565 Display Assembly Replacement, Routing the Display Cable: passo 10, immagine 1 di 1
    • Route the display cable through the routing guides on the palm rest and keyboard.
  11. Dell Inspiron 15 5565 Display Assembly Replacement, Sliding the Display Cable: passo 11, immagine 1 di 2 Dell Inspiron 15 5565 Display Assembly Replacement, Sliding the Display Cable: passo 11, immagine 2 di 2
    • Slide the display cable to the connector on the system board and close the latch to secure the cable.
    • Slide the battery cable to the connector on the system board.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.243 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 583
