Salta al contenuto principale
Dell Inspiron 15 3565 Memory Module Replacement
  1. Dell Inspiron 15 3565 Memory Module Replacement, Popping up the Memory Module: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
  2. Dell Inspiron 15 3565 Memory Module Replacement, Removing the Memory Module: passo 2, immagine 1 di 1
    • Slide and remove the memory module from the memory-module slot.
  3. Dell Inspiron 15 3565 Memory Module Replacement, Align the Notch: passo 3, immagine 1 di 1
    • Align the notch on the memory module with the tab on the memory-module slot and slide it firmly into the slot at an angle.
  4. Dell Inspiron 15 3565 Memory Module Replacement, Installing the Memory Module: passo 4, immagine 1 di 1
    • Press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.121 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
Un commento
What Laptop is this for? I guess the disassembly must be somewhere else.
Don Minish - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 819
