Salta al contenuto principale
Dell Inspiron 15 3541 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 15 3541 Keyboard Replacement, Battery: passo 1, immagine 1 di 2 Dell Inspiron 15 3541 Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 3541 Keyboard Replacement: passo 2, immagine 1 di 1
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
  3. Dell Inspiron 15 3541 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 2 Dell Inspiron 15 3541 Keyboard Replacement, Keyboard: passo 3, immagine 2 di 2
    • Open the laptop and fully extend the screen.
    • Using the nylon spudger, pry the keyboard off the laptop body.
    • Using your hands, remove the keyboard from the body and place it facedown on the track pad. There will be a cord connecting the laptop and the keyboard: keep this cord intact.
  4. Dell Inspiron 15 3541 Keyboard Replacement: passo 4, immagine 1 di 2 Dell Inspiron 15 3541 Keyboard Replacement: passo 4, immagine 2 di 2
    • Unhook the connector and you can now remove the keyboard from the laptop
    • If your version of this laptop has a backlit keyboard, there will be two connectors; the one highlighted orange will also have to be removed.
Conclusione
Altre 8 persone hanno completato questa guida.
Allison
Membro da: 03/04/16
598 Reputazione
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 25
Tutti i Tempi: 3,676
