Salta al contenuto principale
Dell Inspiron 15 3541 Battery Replacement
  1. Dell Inspiron 15 3541 Battery Replacement, Battery: passo 1, immagine 1 di 2 Dell Inspiron 15 3541 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 3541 Battery Replacement: passo 2, immagine 1 di 1
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
Conclusione
Altre 3 persone hanno completato questa guida.
Allison
Membro da: 03/04/16
571 Reputazione
2 Guide realizzate
2 Commenti
Can you do a guide on how to change a CPU on this computer?
F0RS3 Topaz - Replica
During this, the locks in side of this gets dispalced from there places so battery is not locking now. How to repair those locks?.
Vivek Goyenka - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,867
