Salta al contenuto principale
Dell Inspiron 14z-5423 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 14z-5423 Keyboard Replacement, RAM: passo 1, immagine 1 di 2 Dell Inspiron 14z-5423 Keyboard Replacement, RAM: passo 1, immagine 2 di 2
    • Close the display and turn over the computer.
    • Make sure your device is powered down and unplugged before beginning the replacement.
  2. Dell Inspiron 14z-5423 Keyboard Replacement: passo 2, immagine 1 di 1
    • Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
  3. Dell Inspiron 14z-5423 Keyboard Replacement: passo 3, immagine 1 di 2 Dell Inspiron 14z-5423 Keyboard Replacement: passo 3, immagine 2 di 2
    • Lightly lift the RAM cover up and at an angle, away from the computer.
  4. Dell Inspiron 14z-5423 Keyboard Replacement: passo 4, immagine 1 di 2 Dell Inspiron 14z-5423 Keyboard Replacement: passo 4, immagine 2 di 2
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  5. Dell Inspiron 14z-5423 Keyboard Replacement: passo 5, immagine 1 di 2 Dell Inspiron 14z-5423 Keyboard Replacement: passo 5, immagine 2 di 2
    • Remove the popped up RAM by pulling it away from the connection.
    • If it does not pop up pry it out in a steady and straight direction.
  6. Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: passo 6, immagine 1 di 3 Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: passo 6, immagine 2 di 3 Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: passo 6, immagine 3 di 3
    • Lift the plastic yellow flap on the system board.
    • Use the J0 Bit screwdriver to remove the one 6 mm Phillips screw in center of the system board that is connected to the keyboard.
  7. Dell Inspiron 14z-5423 Keyboard Replacement: passo 7, immagine 1 di 1
    • Flip over the computer and open the display.
  8. Dell Inspiron 14z-5423 Keyboard Replacement: passo 8, immagine 1 di 2 Dell Inspiron 14z-5423 Keyboard Replacement: passo 8, immagine 2 di 2
    • Insert a spudger next to the plastic indents located at the top of the keyboard and gently pry to release the securing clips.
    • Lift the keyboard off of the computer.
    • Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.
  9. Dell Inspiron 14z-5423 Keyboard Replacement: passo 9, immagine 1 di 2 Dell Inspiron 14z-5423 Keyboard Replacement: passo 9, immagine 2 di 2
    • Flip the keyboard over onto the palm-rest assembly.
  10. Dell Inspiron 14z-5423 Keyboard Replacement: passo 10, immagine 1 di 3 Dell Inspiron 14z-5423 Keyboard Replacement: passo 10, immagine 2 di 3 Dell Inspiron 14z-5423 Keyboard Replacement: passo 10, immagine 3 di 3
    • Flip the little black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
Conclusione
Altre 2 persone hanno completato questa guida.
Marisol
Membro da: 09/12/16
623 Reputazione
4 Guide realizzate
CSU Fullerton, Team 2-2, Bruce Fall 2016 Membro di CSU Fullerton, Team 2-2, Bruce Fall 2016
CSUF-BRUCE-F16S2G2
5 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,498
