Salta al contenuto principale
Dell Inspiron 14z N114z Display Assembly Replacement
Cosa ti serve
  1. Dell Inspiron 14z N114z Display Assembly Replacement, Remove the Screws: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the display assembly to the computer base.
  2. Dell Inspiron 14z N114z Display Assembly Replacement, Turn over the Computer: passo 2, immagine 1 di 1
    • Turn the computer over and open the display as far as possible.
  3. Dell Inspiron 14z N114z Display Assembly Replacement, Lifting the Connector Latch: passo 3, immagine 1 di 1
    • Lift the connector latch and disconnect the display cable from the connector on the system board.
  4. Dell Inspiron 14z N114z Display Assembly Replacement, Note the Routing: passo 4, immagine 1 di 1
    • Note the routing of the display, camera, and mini-card antenna cables, and remove the cables from their routing guides.
  5. Dell Inspiron 14z N114z Display Assembly Replacement, Remove the Screws: passo 5, immagine 1 di 1
  6. Dell Inspiron 14z N114z Display Assembly Replacement, Lifting the Display Assembly: passo 6, immagine 1 di 1
    • Lift the display assembly off the computer base.
  7. Dell Inspiron 14z N114z Display Assembly Replacement, Placing the Display Assembly: passo 7, immagine 1 di 2 Dell Inspiron 14z N114z Display Assembly Replacement, Placing the Display Assembly: passo 7, immagine 2 di 2
    • Place the NEW display assembly in position and replace the two screws that secure the display assembly to the computer base.
    • NOTE: Ensure that no cables are caught between the display assembly and the computer base.
  8. Dell Inspiron 14z N114z Display Assembly Replacement, Route the Cables: passo 8, immagine 1 di 1
    • Route the display, camera, and mini-card antenna cables through their routing guides.
  9. Dell Inspiron 14z N114z Display Assembly Replacement, Sliding the Display Cable: passo 9, immagine 1 di 1
    • Slide the display cable in the connector on the system board and press down the latch to secure the cable.
  10. Dell Inspiron 14z N114z Display Assembly Replacement, Replace the Screws: passo 10, immagine 1 di 1
    • Turn the computer over.
    • Replace the two screws that secure the display assembly to the computer base.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.243 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 187
