Salta al contenuto principale
Dell Inspiron 14z Hard Drive Replacement
Cosa ti serve
  1. Dell Inspiron 14z Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 3 Dell Inspiron 14z Hard Drive Replacement, Hard Drive: passo 1, immagine 2 di 3 Dell Inspiron 14z Hard Drive Replacement, Hard Drive: passo 1, immagine 3 di 3
    • Here is a Dell Inspiron 14z N411z with a defective hard drive.
    • On the back side is only one cover for the hard drive as well as the memory module.
    • Remove the Phillips screw on the bottom right corner of the cover.
  2. Dell Inspiron 14z Hard Drive Replacement: passo 2, immagine 1 di 3 Dell Inspiron 14z Hard Drive Replacement: passo 2, immagine 2 di 3 Dell Inspiron 14z Hard Drive Replacement: passo 2, immagine 3 di 3
    • Use a plastic opening tool to unsnap the cover from the back case.
    • Move the tool gently along the corner of the cover.
    • The screw that holds the cover on, has a spring clip that keeps the screw attached to the cover. during removal of the screw, this clip might come off.
  3. Dell Inspiron 14z Hard Drive Replacement: passo 3, immagine 1 di 3 Dell Inspiron 14z Hard Drive Replacement: passo 3, immagine 2 di 3 Dell Inspiron 14z Hard Drive Replacement: passo 3, immagine 3 di 3
    • With the removal of the cover, the hard drive is immediately visible. Remove the four screws securing the hard drive bracket.
    • Slide the hard drive to the opposite end of the connector. This will free the connection.
  4. Dell Inspiron 14z Hard Drive Replacement: passo 4, immagine 1 di 3 Dell Inspiron 14z Hard Drive Replacement: passo 4, immagine 2 di 3 Dell Inspiron 14z Hard Drive Replacement: passo 4, immagine 3 di 3
    • Pull gently on the black tab on the hard drive. This will remove the drive and caddy from the computer.
    • Remove the two Phillips screws on the right side,
    • and the two Phillips screws on the left side.
  5. Dell Inspiron 14z Hard Drive Replacement: passo 5, immagine 1 di 1
    • The hard drive is now removed from the caddy and the replacement can be installed.
Conclusione
Altre 2 persone hanno completato questa guida.
oldturkey03
Membro da: 09/29/10
782.133 Reputazione
119 Guide realizzate
Global Fixers Membro di Global Fixers
Community
33 Membri
537 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 12,773
