Salta al contenuto principale
Dell Inspiron 14z 1470 Display Assembly Replacement
Cosa ti serve
  1. Dell Inspiron 14z 1470 Display Assembly Replacement, Remove the Screws: passo 1, immagine 1 di 2 Dell Inspiron 14z 1470 Display Assembly Replacement, Remove the Screws: passo 1, immagine 2 di 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface.
    • Remove the two screws on the base of the computer that secure the display assembly to the computer base.
  2. Dell Inspiron 14z 1470 Display Assembly Replacement, Disconnecting the Display Cable: passo 2, immagine 1 di 1
    • Disconnect the display cable and remove the screw from the system board.
  3. Dell Inspiron 14z 1470 Display Assembly Replacement, Pull the Antenna Cables: passo 3, immagine 1 di 1
    • Pull the Mini-Card antenna cables up through the slot in the computer base.
  4. Dell Inspiron 14z 1470 Display Assembly Replacement, Note the Routing: passo 4, immagine 1 di 1
    • Note the routing of all the cables and remove them from their routing guides.
  5. Dell Inspiron 14z 1470 Display Assembly Replacement, Removing the Display: passo 5, immagine 1 di 2 Dell Inspiron 14z 1470 Display Assembly Replacement, Removing the Display: passo 5, immagine 2 di 2
    • Hold the display while you remove the three screws that secure the display assembly to the computer base.
  6. Dell Inspiron 14z 1470 Display Assembly Replacement, Removing the Display Assembly: passo 6, immagine 1 di 1
    • Lift and remove the display assembly from the computer base.
  7. Dell Inspiron 14z 1470 Display Assembly Replacement, Place the Display Assembly: passo 7, immagine 1 di 1
    • Using the alignment posts, place the NEW display assembly in position and replace the three screws that secure the display assembly to the computer base.
  8. Dell Inspiron 14z 1470 Display Assembly Replacement, Routing the Antenna Cables: passo 8, immagine 1 di 1
    • Route the Mini-Card antenna cables and display cable through their routing guides.
  9. Dell Inspiron 14z 1470 Display Assembly Replacement, Route the Antenna Cables: passo 9, immagine 1 di 1
    • Route the antenna cables through the slot in the computer base.
  10. Dell Inspiron 14z 1470 Display Assembly Replacement, Replace the Screw: passo 10, immagine 1 di 2 Dell Inspiron 14z 1470 Display Assembly Replacement, Replace the Screw: passo 10, immagine 2 di 2
    • Replace the screw and connect the display cable.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.243 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 251
