Salta al contenuto principale
Dell Inspiron 14R-5421 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 14R-5421 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Push the two sliders away from the battery towards the outer edges.
  2. Dell Inspiron 14R-5421 Keyboard Replacement: passo 2, immagine 1 di 2 Dell Inspiron 14R-5421 Keyboard Replacement: passo 2, immagine 2 di 2
    • Remove the battery when it pops up.
  3. Dell Inspiron 14R-5421 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 1
    • Find the clips on the keyboard. They are shown by red arrows.
  4. Dell Inspiron 14R-5421 Keyboard Replacement: passo 4, immagine 1 di 1
    • Using a pry tool, detach the 9 clips from the keyboard by prying at a 90 degree angle.
    • Be careful while detaching and do not lift the keyboard too high or be too rough. The keys can break easily and there is a fragile ribbon cable beneath the keyboard.
  5. Dell Inspiron 14R-5421 Keyboard Replacement: passo 5, immagine 1 di 1
    • Carefully disconnect the ribbon cable from the socket and pull apart.
    • The cable could be connected to other components of the laptop. Proceed with caution because the cable is fragile.
Conclusione
Jared paiva
Membro da: 03/27/18
489 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 571
