Salta al contenuto principale
Dell Inspiron 14R SE 7420 Display Assembly Replacement
Cosa ti serve
  1. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Close the Display: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • Close the display and turn the computer over.
  2. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Remove the Screws: passo 2, immagine 1 di 1
    • Remove the screws that secure the display assembly to the computer base.
  3. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Open the Display: passo 3, immagine 1 di 1
    • Turn the computer over and open the display as far as possible.
  4. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Disconnecting the Antenna Cables: passo 4, immagine 1 di 1
    • Disconnect the antenna cables from the connectors on the Mini-Card.
  5. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Remove the Screws: passo 5, immagine 1 di 1
  6. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Lifting the Display Assembly: passo 6, immagine 1 di 1
    • Lift the display assembly off the computer base.
  7. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Placing the Display Assembly: passo 7, immagine 1 di 2 Dell Inspiron 14R SE 7420 Display Assembly Replacement, Placing the Display Assembly: passo 7, immagine 2 di 2
    • Place the display assembly in position and replace the screws that secure the display assembly to the computer base.
  8. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Connecting the Antenna Cables: passo 8, immagine 1 di 1
    • Connect the antenna cables to the connectors on the Mini-Card.
  9. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Close the Display: passo 9, immagine 1 di 1
  10. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Replace the Screws: passo 10, immagine 1 di 1
    • Replace the screws that secure the display assembly to the computer base.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.309 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.984 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 358
