Salta al contenuto principale
Dell Inspiron 1464 Hard Drive Replacement
Cosa ti serve
  1. Dell Inspiron 1464 Hard Drive Replacement, Remove the Screws: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • Remove the two screws that secure the hard drive assembly to the computer base.
  2. Dell Inspiron 1464 Hard Drive Replacement, Sliding the Hard Drive Assembly: passo 2, immagine 1 di 1
    • Slide the hard drive assembly to the right to disconnect it from the connector on the system board, then lift the hard drive assembly out of the computer base.
  3. Dell Inspiron 1464 Hard Drive Replacement, Remove the Screws: passo 3, immagine 1 di 1
    • Remove the four screws that secure the hard drive to the hard drive bracket.
  4. Dell Inspiron 1464 Hard Drive Replacement, Lifting the Hard Drive: passo 4, immagine 1 di 1
    • Lift the hard drive out of the hard drive bracket.
  5. Dell Inspiron 1464 Hard Drive Replacement, Replace the Screws: passo 5, immagine 1 di 1
    • Replace the four screws that secure the hard drive bracket to the hard drive.
  6. Dell Inspiron 1464 Hard Drive Replacement, Placing the Assembly: passo 6, immagine 1 di 1
    • Place the hard drive assembly in the computer base and push to connect the hard drive assembly to the connector on the system board.
  7. Dell Inspiron 1464 Hard Drive Replacement, Replace the Screws: passo 7, immagine 1 di 1
    • Replace the two screws that secure the hard drive assembly to the computer base.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.091 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,488
