Salta al contenuto principale
Dell Inspiron 1464 Display Assembly Replacement
Cosa ti serve
  1. Dell Inspiron 1464 Display Assembly Replacement, Note the Routing: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface.
    • Note the routing of the Mini-Card antenna cables and remove them from the routing guides on the bottom of the computer.
  2. Dell Inspiron 1464 Display Assembly Replacement, Remove the Screws: passo 2, immagine 1 di 1
    • Remove the two screws on the bottom of the computer that secure the display assembly to the computer base.
  3. Dell Inspiron 1464 Display Assembly Replacement, Pull the Cables Up: passo 3, immagine 1 di 1
    • Pull the Mini-Card antenna cables up through the slot in the computer base.
  4. Dell Inspiron 1464 Display Assembly Replacement, Note the Routing: passo 4, immagine 1 di 1
    • Note the routing of the Mini-Card antenna cables and remove them from the routing guides on the palm rest.
  5. Dell Inspiron 1464 Display Assembly Replacement, Disconnect the Display Cable: passo 5, immagine 1 di 1
    • Disconnect the display cable from the connector on the system board and remove the display cable grounding screw.
  6. Dell Inspiron 1464 Display Assembly Replacement, Remove the Screws: passo 6, immagine 1 di 1
    • Remove the three screws that secure the display assembly to the computer base.
  7. Dell Inspiron 1464 Display Assembly Replacement, Removing the Display Assembly: passo 7, immagine 1 di 1
    • Lift the display assembly off the alignment posts on the computer base.
  8. Dell Inspiron 1464 Display Assembly Replacement, Placing the Display Assembly: passo 8, immagine 1 di 1
    • Use the alignment posts to place the NEW display assembly on the computer base.
  9. Dell Inspiron 1464 Display Assembly Replacement, Replace the Screws: passo 9, immagine 1 di 1
    • Replace the three screws that secure the display assembly to the computer base.
  10. Dell Inspiron 1464 Display Assembly Replacement, Connecting the Display Cable: passo 10, immagine 1 di 1
    • Connect the display cable to the connector on the system board and replace the display cable grounding screw.
  11. Dell Inspiron 1464 Display Assembly Replacement, Routing the Cables: passo 11, immagine 1 di 1
    • Route the Mini-Card antenna cables through the routing guides on the palm rest.
  12. Dell Inspiron 1464 Display Assembly Replacement, Thread the Cables: passo 12, immagine 1 di 1
    • Thread the Mini-Card antenna cables through the slot in the computer base.
  13. Dell Inspiron 1464 Display Assembly Replacement, Replace the Screws: passo 13, immagine 1 di 1
    • Turn the computer over and replace the two screws that secure the display assembly to the computer base.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.243 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 298
