Introduzione
In this guide, we will show you how to remove and replace the Hard Drive.
Cosa ti serve
Remove the two screws that secure the hard-drive cover to the computer base.
Remove the two screws that secure the hard-drive assembly to the computer base.
Pull the pull-tab on the hard-drive assembly towards the right to disconnect the hard-drive assembly from the system board connector.
Lift the hard-drive assembly out of the computer base.
Remove the four screws that secure the hard drive to the hard-drive cage.
Replace the four screws that secure the hard drive to the hard-drive cage.
Place the NEW hard-drive assembly in the computer base.
Slide and connect the hard-drive assembly to the system board connector.
Replace the two screws that secure the hard-drive assembly to the computer base.
Align the tabs on the hard-drive cover with the slots on the computer base and snap the hard-drive cover into place.
Replace the two screws that secure the hard-drive cover to the computer base.
