Introduzione
In this guide, we will show you how to remove and replace the Hard Drive.
  1. WARNING: Before working inside your computer, read the safety information  that shipped with your computer. Follow the procedures in "Before You Begin".
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the two screws that secure the hard-drive cover to the computer base.
  2. Pry out the hard-drive cover using your finger.
    • Pry out the hard-drive cover using your finger.
    • Remove the two screws that secure the hard-drive assembly to the computer base.
    • Pull the pull-tab on the hard-drive assembly towards the right to disconnect the hard-drive assembly from the system board connector.
    • Lift the hard-drive assembly out of the computer base.
    • Remove the four screws that secure the hard drive to the hard-drive cage.
    • Place the NEW hard drive in the hard-drive cage.
    • Replace the four screws that secure the hard drive to the hard-drive cage.
    • Place the NEW hard-drive assembly in the computer base.
    • Slide and connect the hard-drive assembly to the system board connector.
    • Replace the two screws that secure the hard-drive assembly to the computer base.
    • Align the tabs on the hard-drive cover with the slots on the computer base and snap the hard-drive cover into place.
    • Replace the two screws that secure the hard-drive cover to the computer base.
Linea Traguardo
Terrence15
Membro da: 18/12/2017
70.258 Reputazione
442 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 9
