Salta al contenuto principale
Dell Inspiron 1428 Display Assembly Replacement
Cosa ti serve
  1. Dell Inspiron 1428 Display Assembly Replacement, Routing the Cables: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Make note of the Mini-Card antenna cables routing and remove the cables from the routing guides.
  2. Dell Inspiron 1428 Display Assembly Replacement, Remove the Screws: passo 2, immagine 1 di 1
    • Remove the four screws that secure the display assembly to the computer base.
  3. Dell Inspiron 1428 Display Assembly Replacement, Dislodging the Cables: passo 3, immagine 1 di 1
    • Make note of the Mini-Card antenna cable routing and carefully dislodge the antenna cables from the cable routing slot on the computer. Pull the cables away, so that they are clear of the palm rest.
  4. Dell Inspiron 1428 Display Assembly Replacement, Disconnecting the cables: passo 4, immagine 1 di 1
    • Disconnect the display cable, inverter board cable, camera cable, and microphone cables from the respective system board connectors.
  5. Dell Inspiron 1428 Display Assembly Replacement, Remove the Cables: passo 5, immagine 1 di 1
    • Remove the cables from their routing guides.
  6. Dell Inspiron 1428 Display Assembly Replacement, Remove the Screws: passo 6, immagine 1 di 1
    • Remove the two screws that secure the display assembly to the computer base.
  7. Dell Inspiron 1428 Display Assembly Replacement, Lifting the Display Assembly: passo 7, immagine 1 di 1
    • Lift the display assembly off the computer.
  8. Dell Inspiron 1428 Display Assembly Replacement, Placing the Display Assembly: passo 8, immagine 1 di 1
    • Place the NEW display assembly in position and replace the two screws that secure the display assembly to the computer base.
  9. Dell Inspiron 1428 Display Assembly Replacement, Routing the Cable: passo 9, immagine 1 di 1
    • Route all the cables through the routing guides.
  10. Dell Inspiron 1428 Display Assembly Replacement, Connecting the Cables: passo 10, immagine 1 di 1
    • Connect the display cable, inverter board cable, and the camera cable to their respective system board connectors.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.243 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 140
