Salta al contenuto principale
Dell Inspiron 1425 Hard-Drive Assembly Replacement
Cosa ti serve
  1. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Remove the Screw: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the screw that secures the hard-drive assembly to the system board.
  2. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Sliding the Hard Drive Assembly: passo 2, immagine 1 di 1
    • Slide the hard-drive assembly in the direction shown in the illustration to disconnect it from the connector on the system board.
  3. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Lifting the Hard-Drive Assembly: passo 3, immagine 1 di 1
    • Lift the hard-drive assembly off the system board.
  4. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Remove the Screws: passo 4, immagine 1 di 1
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Lifting the Hard Drive: passo 5, immagine 1 di 2 Dell Inspiron 1425 Hard-Drive Assembly Replacement, Lifting the Hard Drive: passo 5, immagine 2 di 2
    • Lift the hard drive away from the hard-drive bracket.
  6. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Placing the Hard Drive: passo 6, immagine 1 di 1
    • Place the hard drive in the hard-drive bracket.
  7. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Replace the Screws: passo 7, immagine 1 di 1
    • Replace the four screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Placing the Hard Drive Assembly: passo 8, immagine 1 di 1
    • Place the NEW hard-drive assembly on the system board.
  9. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Slding the Hard-Drive Assembly: passo 9, immagine 1 di 1
    • Slide the hard-drive assembly to connect it to the connector on the system board.
  10. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Replace the Screw: passo 10, immagine 1 di 1
    • Replace the screw that secures the hard-drive assembly to the system board.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.243 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 124
