Salta al contenuto principale
Dell Inspiron 1410 Memory Modules Replacement
Cosa ti serve
  1. Dell Inspiron 1410 Memory Modules Replacement, Popping up the Memory Module: passo 1, immagine 1 di 1
    • CAUTION: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
  2. Dell Inspiron 1410 Memory Modules Replacement, Removing the Module: passo 2, immagine 1 di 1
    • Remove the module from the connector.
  3. Dell Inspiron 1410 Memory Modules Replacement, Aligning the Notch: passo 3, immagine 1 di 1
    • Align the notch in the module edge connector with the tab in the connector slot.
  4. Dell Inspiron 1410 Memory Modules Replacement, Installing the Memory Module: passo 4, immagine 1 di 1
    • Slide the NEW module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If the module does not click into place, remove the module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.243 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 122
