Salta al contenuto principale
Dell Inspiron 14-7437 Coin Cell Battery Replacement
Cosa ti serve
  1. Dell Inspiron 14-7437 Coin Cell Battery Replacement, Base Cover: passo 1, immagine 1 di 2 Dell Inspiron 14-7437 Coin Cell Battery Replacement, Base Cover: passo 1, immagine 2 di 2
    • Power off your Dell Inspiron 14-7437 before disassembling.
    • Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
    • The two 4.5 mm screws in the center under the rubber mount cannot be removed, but can be loosened.
  2. Dell Inspiron 14-7437 Coin Cell Battery Replacement: passo 2, immagine 1 di 2 Dell Inspiron 14-7437 Coin Cell Battery Replacement: passo 2, immagine 2 di 2
    • Pry open the back cover using a spudger and slide it along the under the cover.
  3. Dell Inspiron 14-7437 Coin Cell Battery Replacement, Battery: passo 3, immagine 1 di 2 Dell Inspiron 14-7437 Coin Cell Battery Replacement, Battery: passo 3, immagine 2 di 2
    • Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
  4. Dell Inspiron 14-7437 Coin Cell Battery Replacement: passo 4, immagine 1 di 1
    • Disconnect the ribbon cables from the motherboard.
  5. Dell Inspiron 14-7437 Coin Cell Battery Replacement: passo 5, immagine 1 di 1
    • Lift up and remove the Lithium-Polymer Battery.
  6. Dell Inspiron 14-7437 Coin Cell Battery Replacement, Speaker: passo 6, immagine 1 di 1
    • Disconnect wires from Motherboard by gently pulling up.
  7. Dell Inspiron 14-7437 Coin Cell Battery Replacement: passo 7, immagine 1 di 3 Dell Inspiron 14-7437 Coin Cell Battery Replacement: passo 7, immagine 2 di 3 Dell Inspiron 14-7437 Coin Cell Battery Replacement: passo 7, immagine 3 di 3
    • Remove the speakers from the case.
  8. Dell Inspiron 14-7437 Coin Cell Battery Replacement, Coin Cell Battery: passo 8, immagine 1 di 1
    • Lift the coin cell battery wire, and carefully remove from motherboard.
    • There are little hooks that the wire is hooked under.
  9. Dell Inspiron 14-7437 Coin Cell Battery Replacement: passo 9, immagine 1 di 2 Dell Inspiron 14-7437 Coin Cell Battery Replacement: passo 9, immagine 2 di 2
    • Remove the Coin-Cell Battery from the case.
    • There is a small amount of adhesive on the bottom of the coin cell battery.
Conclusione
Katelyn Remy
Membro da: 03/10/16
449 Reputazione
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 29
Tutti i Tempi: 1,414
