Salta al contenuto principale
Dell Inspiron 14-7437 Base Cover Replacement
Cosa ti serve
  1. Dell Inspiron 14-7437 Base Cover Replacement, Base Cover: passo 1, immagine 1 di 2 Dell Inspiron 14-7437 Base Cover Replacement, Base Cover: passo 1, immagine 2 di 2
    • Power off your Dell Inspiron 14-7437 before disassembling.
    • Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
    • The two 4.5 mm screws in the center under the rubber mount cannot be removed, but can be loosened.
  2. Dell Inspiron 14-7437 Base Cover Replacement: passo 2, immagine 1 di 2 Dell Inspiron 14-7437 Base Cover Replacement: passo 2, immagine 2 di 2
    • Pry open the back cover using a spudger and slide it along the under the cover.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,761
