Salta al contenuto principale
Dell Inspiron 14-5447 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 14-5447 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop upside down to access the battery.
  2. Dell Inspiron 14-5447 Keyboard Replacement: passo 2, immagine 1 di 2 Dell Inspiron 14-5447 Keyboard Replacement: passo 2, immagine 2 di 2
    • Remove the two black 5.70mm Phillips#0 screws on the case's back.
    • Insert a plastic opening tool into the small slit, centered between the removed screws, and pry open the back cover
  3. Dell Inspiron 14-5447 Keyboard Replacement: passo 3, immagine 1 di 2 Dell Inspiron 14-5447 Keyboard Replacement: passo 3, immagine 2 di 2
    • Remove the two 5.70mm Phillips #0 screws that secure the battery in place on its left side .
    • Treat the battery with care - puncturing or bending may cause damage to the battery and may result in fire or injury.
  4. Dell Inspiron 14-5447 Keyboard Replacement: passo 4, immagine 1 di 2 Dell Inspiron 14-5447 Keyboard Replacement: passo 4, immagine 2 di 2
    • Use the black, plastic flap on the left side to pull the battery out.
    • Slowly lift the flap up and the battery should slide out.
  5. Dell Inspiron 14-5447 Keyboard Replacement, Keyboard: passo 5, immagine 1 di 3 Dell Inspiron 14-5447 Keyboard Replacement, Keyboard: passo 5, immagine 2 di 3 Dell Inspiron 14-5447 Keyboard Replacement, Keyboard: passo 5, immagine 3 di 3
    • Locate the five small slits at the top of the keyboard.
    • Using a plastic opening tool, carefully pry each slit to loosen the keyboard.
    • Slide the keyboard towards the screen at an angle for removal.
    • Be cautious when lifting the keyboard because there are secured, fragile wires connected underneath it.
  6. Dell Inspiron 14-5447 Keyboard Replacement: passo 6, immagine 1 di 2 Dell Inspiron 14-5447 Keyboard Replacement: passo 6, immagine 2 di 2
    • If the keyboard is not lifted with caution, damage to the cables may occur.
    • Lift the keyboard and flip it onto the mouse-pad.
  7. Dell Inspiron 14-5447 Keyboard Replacement: passo 7, immagine 1 di 3 Dell Inspiron 14-5447 Keyboard Replacement: passo 7, immagine 2 di 3 Dell Inspiron 14-5447 Keyboard Replacement: passo 7, immagine 3 di 3
    • Locate the two cable connectors. These connectors secure the cables to the laptop with small, securing flaps.
    • To release the cables, take each flap and flip them upwards to the unlocking position.
    • Pull both the cables out after unlocking and set aside the keyboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 24
Tutti i Tempi: 1,271
