Salta al contenuto principale
Dell Inspiron 14-5447 Fan Replacement
Cosa ti serve
  1. Dell Inspiron 14-5447 Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop upside down to access the battery.
  2. Dell Inspiron 14-5447 Fan Replacement: passo 2, immagine 1 di 2 Dell Inspiron 14-5447 Fan Replacement: passo 2, immagine 2 di 2
    • Remove the two black 5.70mm Phillips#0 screws on the case's back.
    • Insert a plastic opening tool into the small slit, centered between the removed screws, and pry open the back cover
  3. Dell Inspiron 14-5447 Fan Replacement: passo 3, immagine 1 di 2 Dell Inspiron 14-5447 Fan Replacement: passo 3, immagine 2 di 2
    • Remove the two 5.70mm Phillips #0 screws that secure the battery in place on its left side .
    • Treat the battery with care - puncturing or bending may cause damage to the battery and may result in fire or injury.
  4. Dell Inspiron 14-5447 Fan Replacement: passo 4, immagine 1 di 2 Dell Inspiron 14-5447 Fan Replacement: passo 4, immagine 2 di 2
    • Use the black, plastic flap on the left side to pull the battery out.
    • Slowly lift the flap up and the battery should slide out.
  5. Dell Inspiron 14-5447 Fan Replacement, Fan: passo 5, immagine 1 di 1
    • Locate the fan system in the top right corner.
  6. Dell Inspiron 14-5447 Fan Replacement: passo 6, immagine 1 di 2 Dell Inspiron 14-5447 Fan Replacement: passo 6, immagine 2 di 2
    • Look along the wide line of white cable until you find the tab insert.
    • Remove the thick white cable crossing over the fan, using the blue spudger shown, to flip the securing flap holding down the cable.
  7. Dell Inspiron 14-5447 Fan Replacement: passo 7, immagine 1 di 2 Dell Inspiron 14-5447 Fan Replacement: passo 7, immagine 2 di 2
    • Move the cable over to the side to reveal the fan screws.
    • Remove the two black 5.70 mm screws from the fan.
  8. Dell Inspiron 14-5447 Fan Replacement: passo 8, immagine 1 di 2 Dell Inspiron 14-5447 Fan Replacement: passo 8, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to remove the small cable attached to the fan.
  9. Dell Inspiron 14-5447 Fan Replacement: passo 9, immagine 1 di 2 Dell Inspiron 14-5447 Fan Replacement: passo 9, immagine 2 di 2
    • Using the opening tool, pry the fan out.
    • Remove the fan slowly to prevent damage to any wires or cables connected to the device.
  10. Dell Inspiron 14-5447 Fan Replacement: passo 10, immagine 1 di 1
    • Now that the fan is removed, be sure to clean the area under the fan to prevent overheating.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 839
