Salta al contenuto principale
Dell Inspiron 14-5447 Battery Replacement
Cosa ti serve
  1. Dell Inspiron 14-5447 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop upside down to access the battery.
  2. Dell Inspiron 14-5447 Battery Replacement: passo 2, immagine 1 di 2 Dell Inspiron 14-5447 Battery Replacement: passo 2, immagine 2 di 2
    • Remove the two black 5.70mm Phillips#0 screws on the case's back.
    • Insert a plastic opening tool into the small slit, centered between the removed screws, and pry open the back cover
  3. Dell Inspiron 14-5447 Battery Replacement: passo 3, immagine 1 di 2 Dell Inspiron 14-5447 Battery Replacement: passo 3, immagine 2 di 2
    • Remove the two 5.70mm Phillips #0 screws that secure the battery in place on its left side .
    • Treat the battery with care - puncturing or bending may cause damage to the battery and may result in fire or injury.
  4. Dell Inspiron 14-5447 Battery Replacement: passo 4, immagine 1 di 2 Dell Inspiron 14-5447 Battery Replacement: passo 4, immagine 2 di 2
    • Use the black, plastic flap on the left side to pull the battery out.
    • Slowly lift the flap up and the battery should slide out.
Conclusione
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 24
Tutti i Tempi: 3,068
