Introduzione
Is the screen of your Inspiron 14-3452 broken? All you need is a spudger and a screwdriver in order to open up your laptop and replace its screen.
Cosa ti serve
Remove the battery by sliding the battery release latch to the left.
Pull the entire battery away from the backing.
Remove the two Phillips Head 5 mm #0 screws holding the backing in place.
Remove the ten Phillips Head 5 mm #0 screws from the computer backing.
Remove the one Phillips Head 3 mm #0 screw from the computer backing.
