Salta al contenuto principale
Dell Inspiron 14 N4050 Display Assembly Replacement
Cosa ti serve
  1. Dell Inspiron 14 N4050 Display Assembly Replacement, Disconnecting the Display Cable: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Disconnect the display cable from the connector on the system board.
  2. Dell Inspiron 14 N4050 Display Assembly Replacement, Disconnecting the Mini-Card Antenna Cables: passo 2, immagine 1 di 1
    • Disconnect the Mini-Card antenna cables from the connectors on the Mini-Card.
  3. Dell Inspiron 14 N4050 Display Assembly Replacement, Removing the Cables: passo 3, immagine 1 di 1
    • Make a note of the display cable and Mini-Card antenna cables routing and remove the cables from the routing guides.
  4. Dell Inspiron 14 N4050 Display Assembly Replacement, Remove the Screws: passo 4, immagine 1 di 1
    • Remove the two screws that secure the display assembly to the computer base.
  5. Dell Inspiron 14 N4050 Display Assembly Replacement, Removing the Display Assembly: passo 5, immagine 1 di 1
    • Lift and remove the display assembly out of the computer base.
  6. Dell Inspiron 14 N4050 Display Assembly Replacement, Placing the Display Assembly: passo 6, immagine 1 di 1
    • Place the NEW display assembly in position and replace the two screws that secure the display assembly to the computer base.
  7. Dell Inspiron 14 N4050 Display Assembly Replacement, Routing the Display Cable: passo 7, immagine 1 di 1
    • Route the display cable and Mini-Card antenna cables through the routing guides.
  8. Dell Inspiron 14 N4050 Display Assembly Replacement, Connecting the Display Cable: passo 8, immagine 1 di 1
    • Connect the display cable to the connector on the system board.
  9. Dell Inspiron 14 N4050 Display Assembly Replacement, Conencting the Antenna Cables: passo 9, immagine 1 di 2 Dell Inspiron 14 N4050 Display Assembly Replacement, Conencting the Antenna Cables: passo 9, immagine 2 di 2
    • Connect the Mini-Card antenna cables to the Mini-Card.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.243 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 705
