Salta al contenuto principale
Dell Inspiron 14 N4030 Memory Module Replacement
  1. Dell Inspiron 14 N4030 Memory Module Replacement, Popping up the Memory Module: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the module pops up.
  2. Dell Inspiron 14 N4030 Memory Module Replacement, Removing the Memory Module: passo 2, immagine 1 di 2 Dell Inspiron 14 N4030 Memory Module Replacement, Removing the Memory Module: passo 2, immagine 2 di 2
    • Remove the memory module from the memory-module connector.
  3. Dell Inspiron 14 N4030 Memory Module Replacement, Align the Notch: passo 3, immagine 1 di 1
    • Align the notch in the NEW memory module with the tab in the memory- module connector.
  4. Dell Inspiron 14 N4030 Memory Module Replacement, Sliding the Module: passo 4, immagine 1 di 1
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.121 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 130
