Salta al contenuto principale
Dell Inspiron 14 N4030 Hard Drive Replacement
Cosa ti serve
  1. Dell Inspiron 14 N4030 Hard Drive Replacement, Remove the Screws: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 14 N4030 Hard Drive Replacement, Sliding the Assembly: passo 2, immagine 1 di 1
    • Slide the hard-drive assembly out of the hard-drive compartment.
  3. Dell Inspiron 14 N4030 Hard Drive Replacement, Remove the Screws: passo 3, immagine 1 di 1
    • Remove the two screws that secure the hard-drive bezel to the hard drive.
  4. Dell Inspiron 14 N4030 Hard Drive Replacement, Removing the Hard Drive: passo 4, immagine 1 di 1
    • Pull the hard-drive bezel away from the hard drive.
  5. Dell Inspiron 14 N4030 Hard Drive Replacement, Align the Screw Holes: passo 5, immagine 1 di 1
    • Align the screw holes on the NEW hard-drive bezel with the screw holes on the hard drive and replace the two screws.
  6. Dell Inspiron 14 N4030 Hard Drive Replacement, Sliding the Hard-Drive Assembly: passo 6, immagine 1 di 1
    • Slide the hard-drive assembly into the hard-drive compartment until it is fully seated.
  7. Dell Inspiron 14 N4030 Hard Drive Replacement, Replace the Screws: passo 7, immagine 1 di 1
    • Replace the two screws that secure the hard-drive assembly to the computer base.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Terrence15
Membro da: 12/18/17
79.161 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.986 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,076
