Salta al contenuto principale
Dell Inspiron 14 M4010 Hard Drive Replacement
Cosa ti serve
  1. Dell Inspiron 14 M4010 Hard Drive Replacement, Remove the Screws: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • WARNING: If you remove the hard drive from the computer when the drive is hot, do not touch the metal housing of the hard drive.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the two screws that secure the hard-drive assembly to the system board.
  2. Dell Inspiron 14 M4010 Hard Drive Replacement, Disconnecting the Hard-Drive Assembly: passo 2, immagine 1 di 1
    • Slide the hard-drive assembly to disconnect it from the connector on the system board.
  3. Dell Inspiron 14 M4010 Hard Drive Replacement, Lifting the Hard-Drive Assembly: passo 3, immagine 1 di 1
    • Lift the hard-drive assembly away from the system board.
  4. Dell Inspiron 14 M4010 Hard Drive Replacement, Remove the Screws: passo 4, immagine 1 di 1
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 14 M4010 Hard Drive Replacement, Lifting the Hard-Drive Bracket: passo 5, immagine 1 di 1
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 14 M4010 Hard Drive Replacement, Align the Screws: passo 6, immagine 1 di 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive and replace the four screws.
  7. Dell Inspiron 14 M4010 Hard Drive Replacement, Connecting the Hard-Drive Assembly: passo 7, immagine 1 di 1
    • Slide and push the hard-drive assembly to connect it to connector on the system board.
  8. Dell Inspiron 14 M4010 Hard Drive Replacement, Replace the Screws: passo 8, immagine 1 di 1
    • Replace the two screws that secure the hard-drive assembly to the system board.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.034 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 53
