Introduzione
In this guide, we will be showing you how to remove and replace the Display Assembly.
Parti
Nessuna parte richiesta.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in  Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • Remove the two screws that secure the display assembly to the computer base.
  2. Turn the computer over and open the display as far as possible.
    • Turn the computer over and open the display as far as possible.
    • Disconnect the display cable from the connector on the system board, and remove the display cable grounding screw.
    • Make a note of the Mini-Card antenna cables and display cable routing and remove the cables from the routing guides.
    • Hold the display assembly in place and remove the four screws that secure the display assembly to the computer base.
    • Lift and remove the display assembly out of the computer base.
    • Place the NEW display assembly in position and replace the four screws (two on each side) that secure the display assembly to the computer base.
    • Route the Mini-Card antenna cables and display cable through the routing guides.
    • Connect the display cable to the connector on the system board, and replace the display cable grounding screw.
    • Close the display and turn the computer over.
    • Replace the two screws that secure the display assembly to the computer base.
    • CAUTION: Before turning on the computer, replace all screws and ensure that no stray screws remain inside the computer. Failure to do so may result in damage to the computer.
Linea Traguardo
Terrence15
Membro da: 18/12/2017
70.258 Reputazione
442 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 14
