Salta al contenuto principale
Dell Inspiron 14 Gaming 7467 Solid-State Drive Replacement
Cosa ti serve
  1. Dell Inspiron 14 Gaming 7467 Solid-State Drive Replacement, Remove the Screw: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Solid-state drives are fragile. Exercise care when handling the solid-state drive.
    • CAUTION: To avoid data loss, do not remove the solid-state drive while the computer is in sleep or on state.
    • Remove the screw (M2x3) that secures the solid-state drive to the computer base.
  2. Dell Inspiron 14 Gaming 7467 Solid-State Drive Replacement, Remove the Solid-State Drive: passo 2, immagine 1 di 1
    • Slide and remove the solid-state drive from the solid-state drive slot.
  3. Dell Inspiron 14 Gaming 7467 Solid-State Drive Replacement, Align the Notch: passo 3, immagine 1 di 1
    • Align the notch on the solid-state drive with the tab on the solid-state drive slot, and slide the solid-state drive into the solid-state drive slot.
  4. Dell Inspiron 14 Gaming 7467 Solid-State Drive Replacement, Align the Hole: passo 4, immagine 1 di 1
    • Press the other end of the solid-state drive to align the screw hole on the solid-state drive with the screw hole on the computer base.
  5. Dell Inspiron 14 Gaming 7467 Solid-State Drive Replacement, Replace the Screw: passo 5, immagine 1 di 1
    • Replace the screw (M2x3) that secures the solid-state drive to the computer base.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.309 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.984 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 94
