Salta al contenuto principale
Dell Inspiron 14 Gaming 7467 Display Assembly Replacement
Cosa ti serve
  1. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Disconnecting the Camera Cable: passo 1, immagine 1 di 1
  2. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Peel the Camera Cable: passo 2, immagine 1 di 1
    • Peel off the camera cable from the computer base.
  3. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Remove the Screw: passo 3, immagine 1 di 1
    • Remove the screw (M2x3) that secures the display-cable bracket to the system board.
  4. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Removing the Cable Bracket: passo 4, immagine 1 di 1
    • Lift the display-cable bracket off the system board.
  5. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Disconnecting the Display Cable: passo 5, immagine 1 di 1
    • Using the pull-tab, disconnect the display cable from the system board.
  6. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Peeling the Display Cable: passo 6, immagine 1 di 1
    • Peel off the display cable from the computer base.
  7. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Remove the Screws: passo 7, immagine 1 di 1
    • Remove the two screws (M2x3) that secure the display assembly to the computer base.
  8. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Remove the Screws: passo 8, immagine 1 di 1
    • Remove the two screws (M2.5x5) that secure the display assembly to the computer base.
  9. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Remove the Screws: passo 9, immagine 1 di 1
    • Turn the computer over and open the display.
  10. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Lift the Display Assembly: passo 10, immagine 1 di 1
    • Lift the display assembly off the computer base.
  11. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Align the Screw Hole: passo 11, immagine 1 di 1
    • Align the screw holes on the NEW display assembly with the screw holes on the computer base.
  12. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Replace the Screws: passo 12, immagine 1 di 1
    • Replace the two screws (M2.5x5) that secure the display assembly to the computer base.
  13. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Replace the Screws: passo 13, immagine 1 di 1
    • Close the display and turn the computer over.
  14. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Replace the Screws: passo 14, immagine 1 di 1
    • Replace the two screws (M2x3) that secure the display assembly to the computer base.
  15. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Adhere the Cable: passo 15, immagine 1 di 1
    • Adhere the display cable and the camera cable to the computer base.
  16. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Route the Cables: passo 16, immagine 1 di 1
    • Route the antenna cables through the routing guides on the computer base.
  17. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Connect the Cable: passo 17, immagine 1 di 1
    • Connect the display cable and camera cable to the system board.
  18. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Align the Screw Hole: passo 18, immagine 1 di 1
    • Align the screw hole on the display-cable bracket with the screw hole on the system board.
  19. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Replace the Screw: passo 19, immagine 1 di 1
    • Replace the screw (M2x3) that secures the display cable bracket to the system board.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.309 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.984 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 73
