Salta al contenuto principale
Dell Inspiron 14 5443 Hard Drive Replacement
Cosa ti serve
  1. Dell Inspiron 14 5443 Hard Drive Replacement, Removing screws: passo 1, immagine 1 di 1
    • Remove the screws that secure the hard-drive assembly to the base frame.
  2. Dell Inspiron 14 5443 Hard Drive Replacement, Gently Lift Hard-Drive: passo 2, immagine 1 di 1
    • Gently lift the hard-drive assembly out of the base frame and disconnect the hard-drive cable from the hard drive.
  3. Dell Inspiron 14 5443 Hard Drive Replacement, Removing Screws From Bracket: passo 3, immagine 1 di 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  4. Dell Inspiron 14 5443 Hard Drive Replacement, Lifting Bracket: passo 4, immagine 1 di 1
    • Lift the hard-drive bracket off the hard drive
  5. Dell Inspiron 14 5443 Hard Drive Replacement, Placing Bracket: passo 5, immagine 1 di 1
    • Place the hard-drive bracket on the NEW hard drive.
  6. Dell Inspiron 14 5443 Hard Drive Replacement, Aligning the Screws: passo 6, immagine 1 di 1
    • Align the screw holes on the hard drive-bracket with the screw holes on the hard drive.
  7. Dell Inspiron 14 5443 Hard Drive Replacement, Replace the Screws: passo 7, immagine 1 di 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 14 5443 Hard Drive Replacement, Connecting Hard-Drive To Cable: passo 8, immagine 1 di 1
    • Connect the hard-drive cable to the hard drive.
  9. Dell Inspiron 14 5443 Hard Drive Replacement, Placing the Hard-Drive: passo 9, immagine 1 di 1
    • Place the hard-drive assembly in the base frame and align the screw holes on the hard-drive assembly with the screw holes on the base frame.
  10. Dell Inspiron 14 5443 Hard Drive Replacement, Securing the Screws: passo 10, immagine 1 di 1
    • Replace the screws that secure the hard-drive assembly to the base frame.
Linea Traguardo
darrius
Membro da: 03/26/18
5.213 Reputazione
30 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 230
