Salta al contenuto principale
Dell Inspiron 14 5100 RAM Replacement
Cosa ti serve
  1. Dell Inspiron 14 5100 RAM Replacement, Dell Inspiron 14 5100 Disassembly: passo 1, immagine 1 di 3 Dell Inspiron 14 5100 RAM Replacement, Dell Inspiron 14 5100 Disassembly: passo 1, immagine 2 di 3 Dell Inspiron 14 5100 RAM Replacement, Dell Inspiron 14 5100 Disassembly: passo 1, immagine 3 di 3
    • Make sure to disconnect the power source to the device.
    • Remove nine screws securing the base cover of the laptop's keyboard assembly using the Phillips #0 screwdriver.
    • There are 2 sets of screws.
    • Remove the 3 captive screws.
    • Remove the 6M2*6 screws.
  2. Dell Inspiron 14 5100 RAM Replacement: passo 2, immagine 1 di 2 Dell Inspiron 14 5100 RAM Replacement: passo 2, immagine 2 di 2
    • Pry open the laptop to separate the base cover from the keyboard assembly.
    • You may use your fingertips or use plastic opening tools.
  3. Dell Inspiron 14 5100 RAM Replacement, RAM: passo 3, immagine 1 di 1
    • Fold back the thin plastic covers over the RAM slots.
  4. Dell Inspiron 14 5100 RAM Replacement: passo 4, immagine 1 di 2 Dell Inspiron 14 5100 RAM Replacement: passo 4, immagine 2 di 2
    • Using the spudger, pull back the pins holding the RAM in place.
    • The RAM will slightly pop up from the motherboard.
  5. Dell Inspiron 14 5100 RAM Replacement: passo 5, immagine 1 di 1
    • Remove the RAM card from the RAM slot using your fingers. Pull it gently in the direction of the laptop hinge.
    • Repeat Steps 3-5 for the other RAM slot.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,532
