Salta al contenuto principale
Dell Inspiron 14 3468 Hard-Drive Replacement
Cosa ti serve
  1. Dell Inspiron 14 3468 Hard-Drive Replacement, Removing the Screws: passo 1, immagine 1 di 1
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 14 3468 Hard-Drive Replacement, Disconnecting the Hard-Drive Cable: passo 2, immagine 1 di 1
    • Open the latch and disconnect the hard-drive cable from the system board.
  3. Dell Inspiron 14 3468 Hard-Drive Replacement, Lifting the Hard-Drive: passo 3, immagine 1 di 1
    • Lift the hard-drive assembly off the computer base.
  4. Dell Inspiron 14 3468 Hard-Drive Replacement, Removing the Screws: passo 4, immagine 1 di 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 14 3468 Hard-Drive Replacement, Lifting the Hard-Drive  Bracket: passo 5, immagine 1 di 1
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 14 3468 Hard-Drive Replacement, Disconnecting the Interposer: passo 6, immagine 1 di 1
    • Disconnect the interposer from the hard drive.
  7. Dell Inspiron 14 3468 Hard-Drive Replacement, Connecting the Interposer: passo 7, immagine 1 di 1
    • Connect the interposer to the NEW hard drive.
  8. Dell Inspiron 14 3468 Hard-Drive Replacement, Align the Screws: passo 8, immagine 1 di 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  9. Dell Inspiron 14 3468 Hard-Drive Replacement, Securing the Screws: passo 9, immagine 1 di 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  10. Dell Inspiron 14 3468 Hard-Drive Replacement, Align the Screw Holes: passo 10, immagine 1 di 1
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  11. Dell Inspiron 14 3468 Hard-Drive Replacement, Securing the Screws: passo 11, immagine 1 di 1
    • Replace the screws that secure the hard-drive assembly to the computer base.
  12. Dell Inspiron 14 3468 Hard-Drive Replacement, Sliding the Hard-Drive Cable: passo 12, immagine 1 di 1
    • Slide the hard-drive cable into the system board and close the latch to secure the cable.
Linea Traguardo
darrius
Membro da: 03/26/18
5.213 Reputazione
30 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 155
