Salta al contenuto principale
Dell Inspiron 14 3467 Hard-Drive Replacement
Cosa ti serve
  1. Dell Inspiron 14 3467 Hard-Drive  Replacement, Disconnecting The Hard-Drive: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in [http://n Before working inside your computer.]
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Open the latch, and disconnect the hard-drive cable from the connector on the system board.
  2. Dell Inspiron 14 3467 Hard-Drive  Replacement, Removing The Two Screws: passo 2, immagine 1 di 1
    • Remove the two screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
  3. Dell Inspiron 14 3467 Hard-Drive  Replacement, Lifting The Hard-Drive: passo 3, immagine 1 di 1
    • Lift the hard-drive assembly along with its cable off the palm-rest assembly.
  4. Dell Inspiron 14 3467 Hard-Drive  Replacement, Removing The Four Screws: passo 4, immagine 1 di 1
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the harddrive assembly.
  5. Dell Inspiron 14 3467 Hard-Drive  Replacement, Removing The Hard-Drive Bracket: passo 5, immagine 1 di 1
    • Lift the hard-drive assembly off the hard-drive bracket.
  6. Dell Inspiron 14 3467 Hard-Drive  Replacement, Disconnecting The Interposer: passo 6, immagine 1 di 1
    • Disconnect the interposer from the hard drive.
  7. Dell Inspiron 14 3467 Hard-Drive  Replacement, Connecting The Interposer: passo 7, immagine 1 di 1
    • Connect the interposer to the NEW hard drive
  8. Dell Inspiron 14 3467 Hard-Drive  Replacement, Aligning The Screws: passo 8, immagine 1 di 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard-drive assembly.
  9. Dell Inspiron 14 3467 Hard-Drive  Replacement, Screwing The Bracket To Hard-Drive: passo 9, immagine 1 di 1
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the harddrive assembly.
  10. Dell Inspiron 14 3467 Hard-Drive  Replacement, Securing To Hard-Drive Assembly: passo 10, immagine 1 di 1
    • Replace the two screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
Conclusione
darrius
Membro da: 03/26/18
5.213 Reputazione
30 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.986 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 27
Tutti i Tempi: 3,136
