Salta al contenuto principale
Dell Inspiron 14 3465 Base Cover Replacement
Cosa ti serve
  1. Dell Inspiron 14 3465 Base Cover Replacement, Turning The Computer Over: passo 1, immagine 1 di 1
    • Close the display, and turn the computer over.
  2. Dell Inspiron 14 3465 Base Cover Replacement, Removing Eight Screws: passo 2, immagine 1 di 1
    • Remove the eight screws (M2.5x8) that secure the base cover to the palm-rest assembly.
  3. Dell Inspiron 14 3465 Base Cover Replacement, Removing Two Screws: passo 3, immagine 1 di 1
    • Remove the two screws (M2x5) that secure the base cover to the palm-rest assembly.
  4. Dell Inspiron 14 3465 Base Cover Replacement, Rmoving Three Screws: passo 4, immagine 1 di 1
    • Remove the three screws (M2x2) that secure the base cover to the palm-rest assembly.
  5. Dell Inspiron 14 3465 Base Cover Replacement, Open The Display: passo 5, immagine 1 di 1
    • Turn the computer over, and open the display.
  6. Dell Inspiron 14 3465 Base Cover Replacement, Removing Three Screws: passo 6, immagine 1 di 1
    • Remove the three screws (M2x5) that secure the base cover to the palm-rest assembly.
  7. Dell Inspiron 14 3465 Base Cover Replacement, Disconneting The Optical-Drive Cable: passo 7, immagine 1 di 1
    • Open the latch, and disconnect the optical-drive cable from the system board.
  8. Dell Inspiron 14 3465 Base Cover Replacement, Turn Over The Computer: passo 8, immagine 1 di 1
  9. Dell Inspiron 14 3465 Base Cover Replacement, Prying The Base Cover: passo 9, immagine 1 di 1
    • Using a plastic scribe, pry the base cover off the palm-rest assembly.
  10. Dell Inspiron 14 3465 Base Cover Replacement, Lifting The Base Cover: passo 10, immagine 1 di 1
    • Lift the base cover off the palm-rest assembly.
  11. Dell Inspiron 14 3465 Base Cover Replacement, Releasing the optical-drive: passo 11, immagine 1 di 1
    • Release the optical-drive interposer from the tabs, and remove it from the base cover.
  12. Dell Inspiron 14 3465 Base Cover Replacement, Sliding the optical-drive: passo 12, immagine 1 di 1
    • Slide the optical-drive interposer into the tabs on the NEW base cover and snap it into place.
  13. Dell Inspiron 14 3465 Base Cover Replacement, Placing The New Base Cover: passo 13, immagine 1 di 1
    • Place the base cover on the palm-rest assembly and route the optical-drive cable through the slot on the palm-rest assembly.
  14. Dell Inspiron 14 3465 Base Cover Replacement, Sliding The Tabs: passo 14, immagine 1 di 1
    • Slide the tabs on the base cover into the slots on the palm-rest assembly, and snap the base cover into place.
  15. Dell Inspiron 14 3465 Base Cover Replacement, Sliding The Optical-Drive Cable: passo 15, immagine 1 di 1
    • Slide the optical-drive cable into the connector on the system board and press down the latch to secure the cable.
  16. Dell Inspiron 14 3465 Base Cover Replacement, Replacing The Three Screws: passo 16, immagine 1 di 1
    • Replace the three screws (M2x5) that secure the base cover to the palm-rest assembly.
  17. Dell Inspiron 14 3465 Base Cover Replacement, Turn Over The Computer: passo 17, immagine 1 di 1
  18. Dell Inspiron 14 3465 Base Cover Replacement, Replacing The Three Screws: passo 18, immagine 1 di 1
    • Replace the three screws (M2x2) that secure the base cover to the palm-rest assembly.
  19. Dell Inspiron 14 3465 Base Cover Replacement, Replacing The Two Screws: passo 19, immagine 1 di 1
    • Replace the two screws (M2x5) that secure the base cover to the palm-rest assembly.
  20. Dell Inspiron 14 3465 Base Cover Replacement, Replacing The Eight Screws: passo 20, immagine 1 di 1
    • Replace the eight screws (M2.5x8) that secure the base cover to the palm-rest assembly
Conclusione
darrius
Membro da: 03/26/18
5.213 Reputazione
30 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 152
