Introduzione
How To Remove And Replace The Base Cover
Cosa ti serve
Remove the eight screws (M2.5x8) that secure the base cover to the palm-rest assembly.
Remove the two screws (M2x5) that secure the base cover to the palm-rest assembly.
Remove the three screws (M2x2) that secure the base cover to the palm-rest assembly.
Remove the three screws (M2x5) that secure the base cover to the palm-rest assembly.
Open the latch, and disconnect the optical-drive cable from the system board.
Using a plastic scribe, pry the base cover off the palm-rest assembly.
Release the optical-drive interposer from the tabs, and remove it from the base cover.
Slide the optical-drive interposer into the tabs on the NEW base cover and snap it into place.
Place the base cover on the palm-rest assembly and route the optical-drive cable through the slot on the palm-rest assembly.
Slide the tabs on the base cover into the slots on the palm-rest assembly, and snap the base cover into place.
Slide the optical-drive cable into the connector on the system board and press down the latch to secure the cable.
Replace the three screws (M2x5) that secure the base cover to the palm-rest assembly.
Replace the three screws (M2x2) that secure the base cover to the palm-rest assembly.
Replace the two screws (M2x5) that secure the base cover to the palm-rest assembly.
Replace the eight screws (M2.5x8) that secure the base cover to the palm-rest assembly
