Salta al contenuto principale
Dell Inspiron 14 3462 Display Assembly Replacement
Cosa ti serve
  1. Dell Inspiron 14 3462 Display Assembly Replacement, Peel the Tape: passo 1, immagine 1 di 1
  2. Dell Inspiron 14 3462 Display Assembly Replacement, Disconnecting the Display Cable: passo 2, immagine 1 di 1
    • Open the latch that secures the display cable into position.
    • Disconnect the display cable from the system board.
  3. Dell Inspiron 14 3462 Display Assembly Replacement, Remove the Antenna Cable: passo 3, immagine 1 di 1
    • Note the antenna-cable routing, and remove the antenna cable from the routing guides on the palm-rest assembly.
  4. Dell Inspiron 14 3462 Display Assembly Replacement, Turn the Computer Over: passo 4, immagine 1 di 1
    • Turn the computer over and open the display at an angle of 90 degrees.
    • Turn the computer over and place it on the edge of the table in a position that allows access to the screws on the display hinges.
  5. Dell Inspiron 14 3462 Display Assembly Replacement, Remove the Screws: passo 5, immagine 1 di 1
    • Remove the three screws (M2.5x8) that secure the display-hinge brackets to the palm-rest assembly.
  6. Dell Inspiron 14 3462 Display Assembly Replacement, Lifting the Display Assembly: passo 6, immagine 1 di 1
    • Carefully lift the display assembly from the palm-rest assembly.
  7. Dell Inspiron 14 3462 Display Assembly Replacement, Placing the Display Assembly: passo 7, immagine 1 di 1
    • Carefully place the display assembly on a clean and flat surface.
  8. Dell Inspiron 14 3462 Display Assembly Replacement, Placing the Display Assembly: passo 8, immagine 1 di 1
    • Place the NEW display assembly at the edge of the table.
  9. Dell Inspiron 14 3462 Display Assembly Replacement, Align the Screw Holes: passo 9, immagine 1 di 1
    • Align the screw holes on the palm-rest assembly with the screw holes on the display hinges.
  10. Dell Inspiron 14 3462 Display Assembly Replacement, Replace the Screws: passo 10, immagine 1 di 1
    • Replace the three screws (M2.5x8) that secure the display hinges to the palm-rest assembly.
  11. Dell Inspiron 14 3462 Display Assembly Replacement, Route the Cables: passo 11, immagine 1 di 1
    • Route the antenna cables through the routing guides on the palm-rest assembly.
  12. Dell Inspiron 14 3462 Display Assembly Replacement, Connecting the Display Cable: passo 12, immagine 1 di 1
    • Connect the display cable from the system board.
  13. Dell Inspiron 14 3462 Display Assembly Replacement, Close the Latch: passo 13, immagine 1 di 1
    • Close the latch that secures the display cable to the system board.
  14. Dell Inspiron 14 3462 Display Assembly Replacement, Adhering the Tape: passo 14, immagine 1 di 1
    • Adhere the tape that secures the display cable to the system board.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.243 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 230
