Salta al contenuto principale
Dell Inspiron 14 3459 Memory Modules Replacement
  1. Dell Inspiron 14 3459 Memory Modules Replacement, Popping up the Memory Module: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Using your fingertips, spread apart the securing clips at each end of the memory-module slot until the memory module pops up.
  2. Dell Inspiron 14 3459 Memory Modules Replacement, Removing the Memory Module: passo 2, immagine 1 di 1
    • Slide and remove the memory module from the memory-module slot.
  3. Dell Inspiron 14 3459 Memory Modules Replacement, Align the Notch: passo 3, immagine 1 di 1
    • Align the notch on the NEW memory module with the tab on the memory-module slot.
  4. Dell Inspiron 14 3459 Memory Modules Replacement, Sliding the Memory Module: passo 4, immagine 1 di 1
    • Slide the memory module firmly into the slot and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.243 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 301
