Salta al contenuto principale
Dell Inspiron 13z N311z Display Assembly Replacement
Cosa ti serve
  1. Dell Inspiron 13z N311z Display Assembly Replacement, Remove the Screws: passo 1, immagine 1 di 1
    • Follow the instructions in "Before You Begin".
    • Remove the two screws that secure the display panel to the chassis.
  2. Dell Inspiron 13z N311z Display Assembly Replacement, Open the Display: passo 2, immagine 1 di 1
    • Turn the computer over and open the display as far as possible.
  3. Dell Inspiron 13z N311z Display Assembly Replacement, Remove the Cables: passo 3, immagine 1 di 1
    • Make a note of the routing of the Mini-Card antenna cables and the display cables. Remove the cables from the routing guides.
  4. Dell Inspiron 13z N311z Display Assembly Replacement, Remove the Screws: passo 4, immagine 1 di 1
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  5. Dell Inspiron 13z N311z Display Assembly Replacement, Disconnect the Display Cable: passo 5, immagine 1 di 1
    • Make a note of the cable routing and disconnect the display cable and the wireless card antenna cables from the connectors on the Mini-Card.
  6. Dell Inspiron 13z N311z Display Assembly Replacement, Removing the Display Assembly: passo 6, immagine 1 di 1
    • Lift and remove the display assembly off the computer base.
  7. Dell Inspiron 13z N311z Display Assembly Replacement, Replace the Screws: passo 7, immagine 1 di 2 Dell Inspiron 13z N311z Display Assembly Replacement, Replace the Screws: passo 7, immagine 2 di 2
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  8. Dell Inspiron 13z N311z Display Assembly Replacement, Routing the Cables: passo 8, immagine 1 di 1
    • Route the Mini-Card antenna cables and the display cable through the slot on the computer base.
  9. Dell Inspiron 13z N311z Display Assembly Replacement, Connecting the Display Cable: passo 9, immagine 1 di 1
    • Connect the display cable to the connector on the system board.
Conclusione
Terrence15
Membro da: 12/18/17
79.243 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 304
