Salta al contenuto principale
Dell Inspiron 13z N311z Battery Replacement
  1. Dell Inspiron 13z N311z Battery Replacement, Popping out the Battery: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn off the computer and turn it over.
    • Slide both the battery release latches to the unlock position. The battery pops out of the battery bay.
  2. Dell Inspiron 13z N311z Battery Replacement, Lifting the Battery: passo 2, immagine 1 di 1
    • Lift the battery out of the battery bay. After the battery is removed, the left battery latch must be in the locked position.
Conclusione
Terrence15
Membro da: 12/18/17
79.034 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 124
