Introduzione
In this guide, we will be showing you how to remove and replace the Hard-Drive Assembly.
Parti
Nessuna parte richiesta.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in  Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the four screws that secure the hard-drive assembly to the computer base.
  2. Lift the connector latch and pull the pull-tab to disconnect the hard-drive cable from the connector on the system board.
    • Lift the connector latch and pull the pull-tab to disconnect the hard-drive cable from the connector on the system board.
  3. Lift the hard-drive assembly out of the computer base.
    • Lift the hard-drive assembly out of the computer base.
  4. Remove the four screws that secure the hard-drive bracket to the hard drive.
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  6. Lift the hard drive out of the hard-drive bracket. Lift the hard drive out of the hard-drive bracket.
    • Lift the hard drive out of the hard-drive bracket.
  7. Pull the interposer to disconnect it from the hard drive.
    • Pull the interposer to disconnect it from the hard drive.
  8. Connect the interposer to the NEW hard drive.
    • Connect the interposer to the NEW hard drive.
  9. Place the hard drive in the hard-drive bracket. Place the hard drive in the hard-drive bracket.
    • Place the hard drive in the hard-drive bracket.
  10. Replace the four screws the hard-drive bracket to the hard drive.
    • Replace the four screws the hard-drive bracket to the hard drive.
  11. Place the hard-drive assembly in the computer base.
    • Place the hard-drive assembly in the computer base.
  12. Slide the hard-drive cable into the connector on the system board and press down on the latch to secure the hard-drive cable.
    • Slide the hard-drive cable into the connector on the system board and press down on the latch to secure the hard-drive cable.
  13. Replace the four screws that secure the hard-drive assembly to the computer base.
    • Replace the four screws that secure the hard-drive assembly to the computer base.
Linea Traguardo
Terrence15
Membro da: 18/12/2017
70.653 Reputazione
442 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 38
