Salta al contenuto principale
Dell Inspiron 13z 5323 Hard Drive Replacement
Cosa ti serve
  1. Dell Inspiron 13z 5323 Hard Drive Replacement, Remove the Screws: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 13z 5323 Hard Drive Replacement, Disconnecting the Hard-Drive Cable: passo 2, immagine 1 di 2 Dell Inspiron 13z 5323 Hard Drive Replacement, Disconnecting the Hard-Drive Cable: passo 2, immagine 2 di 2
    • Disconnect the hard-drive cable connector from the hard-drive assembly.
  3. Dell Inspiron 13z 5323 Hard Drive Replacement, Lifting the Hard-Drive Assembly: passo 3, immagine 1 di 1
    • Lift the hard-drive assembly away from the computer base.
  4. Dell Inspiron 13z 5323 Hard Drive Replacement, Remove the Screws: passo 4, immagine 1 di 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 13z 5323 Hard Drive Replacement, Lifting the Hard-Drive Bracket: passo 5, immagine 1 di 2 Dell Inspiron 13z 5323 Hard Drive Replacement, Lifting the Hard-Drive Bracket: passo 5, immagine 2 di 2
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 13z 5323 Hard Drive Replacement, Align the Screw Holes: passo 6, immagine 1 di 1
    • Align the screw holes on the hard drive-bracket with the screw holes on the NEW hard drive.
  7. Dell Inspiron 13z 5323 Hard Drive Replacement, Replace the Screws: passo 7, immagine 1 di 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 13z 5323 Hard Drive Replacement, Connecting the Hard-Drive Cable: passo 8, immagine 1 di 2 Dell Inspiron 13z 5323 Hard Drive Replacement, Connecting the Hard-Drive Cable: passo 8, immagine 2 di 2
    • Connect the hard-drive cable connector to the hard-drive assembly.
  9. Dell Inspiron 13z 5323 Hard Drive Replacement, Align the Screw Holes: passo 9, immagine 1 di 1
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  10. Dell Inspiron 13z 5323 Hard Drive Replacement, Replace the Screws: passo 10, immagine 1 di 1
    • Replace the screws that secure the hard-drive assembly to the computer base.
Conclusione
Terrence15
Membro da: 12/18/17
79.161 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.986 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 595
