Salta al contenuto principale
Dell Inspiron 13z 5323 Battery Replacement
Cosa ti serve
  1. Dell Inspiron 13z 5323 Battery Replacement, Battery: passo 1, immagine 1 di 3 Dell Inspiron 13z 5323 Battery Replacement, Battery: passo 1, immagine 2 di 3 Dell Inspiron 13z 5323 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Remove nine screws from the bottom case.
    • The highlighted captive screw on the base cover is held in place with a washer, so when it is loosened and the cover is removed, the screw will stay in the plate.
    • Once the captive screw is loosened, remove the small base cover on the bottom of the device.
  2. Dell Inspiron 13z 5323 Battery Replacement: passo 2, immagine 1 di 3 Dell Inspiron 13z 5323 Battery Replacement: passo 2, immagine 2 di 3 Dell Inspiron 13z 5323 Battery Replacement: passo 2, immagine 3 di 3
    • There are 3 slots on the top of the keyboard where you will have to use a thin tool, such as a flathead screwdriver to push the tabs so the keyboard will pop out.
    • Be careful when pushing in the keyboard tabs, as they may break if they if too much pressure is applied to them.
    • You will have to flip a small tab up where the ribbon connector goes into the insert, so the connector can be released and the keyboard can be removed.
  3. Dell Inspiron 13z 5323 Battery Replacement: passo 3, immagine 1 di 3 Dell Inspiron 13z 5323 Battery Replacement: passo 3, immagine 2 di 3 Dell Inspiron 13z 5323 Battery Replacement: passo 3, immagine 3 di 3
    • Remove the highlighted 4 screws and then use the plastic separator to remove the palm rest.
    • Be careful when separating the palm rest from the laptop, because being too aggressive with it can cause the small clips that hold the palm rest in place to break .
  4. Dell Inspiron 13z 5323 Battery Replacement: passo 4, immagine 1 di 3 Dell Inspiron 13z 5323 Battery Replacement: passo 4, immagine 2 di 3 Dell Inspiron 13z 5323 Battery Replacement: passo 4, immagine 3 di 3
    • Remove the screws surrounding the battery and unplug the cable in the top left corner to then remove the battery.
Conclusione
Chase Hussey
Membro da: 03/08/17
201 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 21
Tutti i Tempi: 876
