Salta al contenuto principale
Fix Your Stuff
Right to Repair
Parts & Tools
Introduzione
In this guide, we will be showing you how to remove and replace the Memory Module.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in  Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  2. Remove the memory module from the memory module connector. Remove the memory module from the memory module connector.
    • Remove the memory module from the memory module connector.
  3. Align the notch in the NEW memory module with the tab in the memory module connector.
    • Align the notch in the NEW memory module with the tab in the memory module connector.
  4. Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the  click, remove the memory module and reinstall it.
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Conclusione
Terrence15
Membro da: 18/12/2017
71.723 Reputazione
442 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
18 Membri
1.816 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 33
