Introduzione
In this guide, we will show you how to remove and replace the Display Assembly.
Parti
Nessuna parte richiesta.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in  Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer)
    • Disconnect the display cable and the camera cable from their respective system board connectors.
  2. Remove the six screws (three on each side) that secure the display assembly to the computer base.
    • Remove the six screws (three on each side) that secure the display assembly to the computer base.
    • Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
    • Lift the display assembly off the computer.
    • Place the NEW display assembly in position and replace the six screws (three on each side) of the display assembly.
    • Route the Mini-Card antenna cables through the routing guides.
    • Connect the display cable and the camera cable to their respective system board connectors.
Linea Traguardo
Terrence15
Membro da: 18/12/2017
70.198 Reputazione
442 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 22
