Introduzione
In this guide, we will show you how to remove and replace the Memory Module.
  1. Follow the procedures in Before You Begin.
    • Follow the procedures in Before You Begin.
    • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
  2. Remove the module from the connector.
    • Remove the module from the connector.
    • Align the notch in the module edge connector with the tab in the connector slot.
    • Slide the module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If the module does not click into place, remove the module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Linea Traguardo
Terrence15
Membro da: 18/12/2017
70.198 Reputazione
442 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 11
